Old 11-17-2012, 07:13 AM
tmvE39/E53/Z32's Avatar
Mein Auto: Dinan //M5, Dinan 4.8iS,
Originally Posted by FUNCHIZ View Post
replaced break pads and this mesage displays '' chck breakliness'' 2. two headlights -inner ones can't go off,had to disconect them, thirdly my odometer not working. how best can i have this fixed
1. Did you replace the brake wear sensor? You might not put them back in right. You can NOT re-use them once they stripped.
2. That's your DRL when your engine is running. You need to code the LCM to turn them off. If they are on even without the key in the ignition, you might have problem with the LCM
3. Speedometer is fine? How about cruise control? Any other light on the cluster?
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
