Old 11-18-2012, 10:06 AM
Mein Auto: 2007-335 HTC
It was easy now looking back on it, its not difficult just painful. I have a 335i convertable, if thats what you have. you have to take the whole console out to get to the socket. and in order to get the console out you have to start at the rear console, pulling the cup holder out and the rear cubby box, under the rear cubby box are 2 bolts which you remove, then pop the rear vents out, 4 torx screws to remove, then pull the rear console out, next work on the front, gear shift lever boot, see you tubetube for directions, then the plastic cover pops off, hand brake boot to remove, several screws and 2 more bolts, work the front console off, taking all the wire connections looses, but you have to pull the whole front console out to get the aux/usb socket out
have fun
Hondo
