Old 11-18-2012, 11:16 AM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
when you have no ideal what the blue and red dot means on the center vent, and can't figure out why you get no heat out of them.
trying to figure why the temp gauge reads -40.
won't use the cup holders out of fear of breaking them.
your out side in 15 degree weather pouring hot water onto the latch so the door will close.
you want to plasti dip everything you can have a sport moldel
when your ride is broken and won't run, sittin in the same spot for months, and it still looks better then all of the other neighbors cars that do run.
and last but not least............................................. ...........................
your sitting in the drive way, playing with the sun visor looking like and idiot just to see if the ignition switch is bad. knowing no other car has this unique testing procedure.
The more you complain, the longer God makes you live. SPHOBA #00002
