Old 11-19-2012, 12:45 AM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
A short to ground in the switch/instrumentation illumination wiring (58g, 0.5 GR/RT) would cause what you describe. Finding the short can be a fair amount of trouble as that wiring goes all over the place. On a positive note, your PWM dimmer control should be short circuit protected. Once you find and remove the short, everything should recover since. If you had a Z3 or Compact, you might very well have to replace or repair its light switch / rheostat.
Do you have or can you borrow a clamp on, hall effect, DC ammeter probe? I pinched a wire to the chassis after I added electric rear vent windows, and found it in under 15 minutes with such a probe. (I can only take a third of the credit for the short.)
