Bimmerfest - BMW Forums - View Single Post - Leaking brake connections
Old 11-19-2012, 09:28 AM
BMWFatherFigure's Avatar
Old School
Those fittings are unpressurised fluid supply. They seal with an 'O'ring. From memory the 'hex' area is cast into the cylinder and does not rotate or lock down the inlet tubes. If those seals have gone I would remove and overhaul the complete cylinder. IMO don't use any sealant to fix the leak, replace the aged seals. Here the parts from a brake shop would be about $30 for a complete kit.
Current:
E38 Parts Car
Previous:
