crank position sensor
Any way to test crank position sensor?
I swapped Solenoids with the same numbers and colors... Light green ones with the number 464.....with no result. Not sure witch solenoid runs the fuel pump though...
I do not sense the fuel pump running with one hand on the key and the other on the pump.
When I powered the pump directly, it was pretty quiet. Did not rev very high to my mind. I tried powering the pump directly while my kid turned the key....nada, reversed polarity...nada
I was hoping for a straight up diagnostic, but this is part of the joy...mixed signals
Reason: addition idea
