Old 11-20-2012, 12:39 AM
BMWFatherFigure's Avatar
Old School
RB - You're punching above your weight. You remove the battery terminal and connect there so you can see when the current drops. If you prod about in the fuse box you COULD accidently hook accross a live pin load and then watch all the smoke come out of your ammeter set at 300ma. Pulling fuses out will not INCREASE the drain current - prodding the the fuse box - not a good idea.i
Current:
E38 Parts Car
Previous:
