i just rechecked all of the connections in the trunk, to the alternator, the starter and the ground that goes to the passenger side motor mount and they are all fine. I have a 900cranking amp battery pack connected to the engine hook up's and a brand new battery in the car and it cranks plenty fast until it cuts out. If you truly believe it is a starting system problem, the car should pop start right?
