Bimmerfest - BMW Forums - View Single Post - 540i cranks one revolution and stops. Will not start
Old 11-20-2012, 02:14 PM
neonphire8604 neonphire8604 is offline
Mein Auto: 1998 BMW 540i
Originally Posted by edjack View Post
I sure can't help anymore, BUT, did the car start normally before the flywheel and clutch replacement? If so, the work and/or parts have something to do with it.
If the DME does not get the correct signal from the crank sensor, the car will not start. There are some smart scan tools out there that can monitor the crank sensor signal. It would be prudent to check that before pulling the trans.
sorry, I didn't see your post. I drove the car right into the garage so it started and ran just fine before this whole ordeal. This thing is just a nightmare.
