Old 11-20-2012, 04:02 PM
poolman poolman is offline
Mein Auto: 525i station wagon
On the Vanos question--If you Diy you should check out the Besian System website and read the diy there and the reasons for doing this work--this will bging your car back to life. On the fuel trim issue--use the search engine at the top of the page and type in Vacuum leaks revisited--that will give you all the spots we know of to search and destroy Vacuum leaks--Hope that helps
