Old 11-21-2012, 04:14 AM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
I do when its cold out. Somethings wrong with the actuators that control which vents the airflow is coming out of so I have to overcompensate by turning the temp up and putting the blower on high.
Also if your display isn't showing anything its gotta have the transistor resoldered. Mine was like yours when bought the car but I had a friend with a steady hand resolver the transistor and lo and behold there was light!
Sent from my DROID4 using Bimmer App
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
