11-21-2012, 10:49 AM
bimmerfest Supporting Member
Mein Auto: '96 328iC, '04 325Ci
Don't know what bleeding procedure you're using but this one has always worked for me. You have to add the coolant VERY slowly and let it keep overflowing until there are no bubbles, not even tiny ones coming out of the bleed screw hole. As the DIY states do not do this with the engine running. Also make certain all your heat controls are set to the highest setting, both the temp control and the cool/heat control.
'96 328iC "Marie"
