Bimmerfest - BMW Forums - View Single Post - Front Seat Button and sleep mode
Old 11-21-2012, 03:44 PM
sparks59 sparks59 is offline
Mein Auto: toyota landcruiser
Yes checked thoroughly again today and drain down to 0.02 amps. Found many fault codes on nearly every ecu when scanned. Cleared fault codes ok. I tried to register battery using LAUNCH but although I could access power module live data and actuations could not find relevant section for new battery registration.
But disconnecting negative lead overnight certainly sorted out the drain. I think the old faulty battery going very low voltage confused all the control units.
