Old 11-24-2012, 02:45 AM
TOGWT TOGWT is offline
Mein Auto: Jaguar XKE
Originally Posted by Marktroy19 View Post
TOGWT... What would you recommend as a leather protectant for my interior?
Protection - is essential as it will protect the surface finish (Leather Master™ - Protection Cream) as a sacrificial layer; this way you are not actually cleaning the Leather's original surface, but cleaning from the surface of the protection. It also makes dirt easier to clean off
With leather, it is much easier to practice prevention than it is to try to resolve major challenges after the fact. Leather Protection will also work to remove small surface scratches on finished leathers. In general, Leather Protection Cream is used as a final step in combination with most of the Leather Master products.
Leather Master™ - Protection Cream (a Scotchgard™ type product specifically formulated for lather) the polymers penetrate the surface of finished leather and cross-link to form a durable protective film that is breathable, allowing transpiration and keeps the leather supple. Being aqueous (water- based) it restores moisture to finished leather and provides a protective sacrificial barrier against all kinds of soiling, water, oil, alcohol-based stains and perspiration marks, so you are cleaning the protective layer
Ultra violet (UV) protection - 303® Aerospace Protectant - is water and will provide invaluable ultra violet (UV) radiation protection against photo degradation (fading) protection; especially in a roadster or convertible vehicles. It doesn’t contain silicones, so it won't attract and capture dust. You should apply to a clean surface (it doesn’t contain any cleaning agents)
It will not prevent finished leather hydration (transpiration and evaporation of moisture) as its water-based, although it coats the leather with a micro fine coating; it will not seal it per se.
Note: this product does NOT air dry. Use a second dry cloth to finish the application process. Extra buffing with at dry cloth increases bonding, repellence and durability
~ Providing unbiased opinions that Professionals and Enthusiasts Use and Trust ~ Blog-http://togwt1980.blogspot.com
