11-25-2012, 03:02 PM
E36 ///M3 Clone 328iS
Mein Auto: E36 M3 Clone 328iS
Okay so it takes two people to bleed my system properly, so I empyted the system, drained the block. Then filled up the resivor while person #2 started the car and held the throttle at 2k-2.5k RPM. with heat and fan on full blast. As I continued to fill the resivor allot of bubbles came through the bleeder screw, took over an extra gallon of 50/50 mix to fully bleed it. . All in all make sure you have 2 gal antifreeze and 2 gal distilled in my case it took 3 gal of both, " air sucking wh*re imo" until the fluid from the bleeder screw was clear from bubbles. Now I get heat when I idle as well as driving.. works perf . Oh and front end was jacked up about a foot.
Sent from my C771 using Bimmer App
