How is that even possible?
I answered your question regarding the whistling CCV and less than two hours later you replaced it with the original AND put in a lower pan gasket??
Maybe I am missing something. You stated you did this work yesterday and discovered the whistling. Then you state you let it sit overnight and noticed the leaking lower pan gasket. Yet there was only a 2 hour window between my answer and your fix?
