Old 11-28-2012, 04:47 PM
akoposipeter akoposipeter is offline
Mein Auto: X3
Unhappy SSS Progman v32 DME/DDE Software Update Failed
Hi All,
I have problem with coding DME/DDE in my My 2004 X3 2.5i.
Now my car wont start but the engine is cranking. HELP!!!
I used SSS Progman v32
Operations:
Measures plan selected - OK
CKM Backup Successful - OK
Flashed via DIAGBUS:
X/Program DME/DDE
X/Diagnostic trouble 2082 (CoApi) - Error in cleaning flash
CKM Restoration Successful - OK
! Could not completely clear fault code memories
! The following ECU9(s) contain(s) furthier entries in the fault memory
-GM
-VTG
-KOMBI
-MRS
Need your help Guys!!! need ride to go to work. Thanks
ID:	351252   Click image for larger version
