My cluster was originally a LOW OBC. I bought a High OBC and imported the harness pieces pictured in the instructions, and wired it in accordingly. Only issue I have (more because I have been too lazy to correct the punch-wiring like I need to) is that pushing in and holding the button on the turn signal stalk doesn't reset the mpg or avg speed. My assumption is that I punched one of the wires into the wrong spot on the patch panel underneath the glove compartment. There are a lot of wires with very similar colors and patterns. That was the toughest part of the entire process. Other than that, the cluster works PERFECTLY. Not sure about MID and so on, I don't know much about the electronics, unfortunately. I don't have NAV either.
