Thanks, but does this cover the 03 745i? Can I check fluid from the computer on my car? Also, when I start car do I put plug on first and remove again, or just leave off and screw in as per above? I watched a video online and the guy was going from P to N D and R, but he didn't do the 1-6. Is he correct or these directions? Do I bother with N and R? Should I just do all? Do I need to check fluid again after going through the gears? Thanks! Keep in mind I am not dropping pan it was done a while back. Just using drain plug and fill plug. I will make sure fill plug loosens before proceeding with anything.
