Old 11-29-2012, 04:00 PM
BuiltnBoostedZ BuiltnBoostedZ is offline
Mein Auto: X3 xDrive35i & 350Z TT
PROCEDURE
Fluid Level Checking Procedure for all Transmissions without a Dipstick:
The transmission temperature must be between 30C and 50C before checking can begin. Use the DIS or the MODIC to determine the transmission temperature.
The vehicle must be level and without load. With the engine running, switch on the air conditioning. This will increase the idle speed and ensure that all oil passages in the transmission are filled with oil.
Step on the brake firmly, apply parking brake fully and move the selector lever through each gear position, pausing briefly in each gear.
With the engine running and the selector lever in Park position, remove the filler plug located on the transmission (see picture for location). If a small stream of oil runs out, the fluid level is correct.
If no oil runs out when the filler plug is removed, the fluid level is too low. Add oil until it starts to overflow.
With the engine running, reinstall the oil filler plug and tighten to proper torque. (Refer to section below for proper tightening torque)
Fluid Level Checking Procedure for all Transmissions with a Dipstick
(As of 02/91 the THM R1 transmissions are not equipped with a dipstick):
Pull out dipstick and wipe clean with a lint free cloth
Reinsert dipstick completely. Pull out dipstick and place bottom tip on a level surface, measure level from bottom tip as shown.
350Z TT - SOLD!
2004 745Li - SOLD
2011 X3 xDrive35i
