Old 11-29-2012, 04:19 PM
Stoomey006 Stoomey006 is offline
Mein Auto: 1987 325i
87 325i fuel pump issue
Hey guys, my 325i was sporadically loosing power then bumping back on more and more frequently until finally it died all together.. It was like the fuel pump was turning off and on off and on... Now I've done plugs wires fuel filter and both fuel system relays and the fuel pump does not turn on unless I bridge the relay terminals w a jumper wire in which case the pump fires right up :-/... Any ideas of diagnostics I can perform or ideas of what I can do before gambling w replacing te fuel pump?
Thank you all so much for your time!
-sean
