11-29-2012, 07:42 PM
livin large
Originally Posted by woodenbmw
I don't know about testing the gauge sensor, on my 87 325e however, the fan operates from two sensors located on the radiator. One for low speed, the other for the high speed fan. You can test them by jumping the terminals together. If the fan comes on, replace the sensor. I hope this helps.
this /\/\ is the aux fan mainly used when running ac. the fan clutch is oil operated. the hotter the oil within the fan clutch, the more it engages and "locks". if it is good, after you shut off the engine after running it for a bit, you should have good resistance. if it is bad it will spin somewhat freely. or you can do the newspaper test.
