11-30-2012, 02:23 PM
Mein Auto: 2013 X3 28i
Originally Posted by shawnsheridan
Ok. Incidentally, I wrote the initial instructions, and the copy I just shared with you, v.2, varies only slight from the original. What you had is something different. Since you mentioned a batch file, I think those are the instructions that go along with one of April1's Install batch files. You should be good to go know though.
I think I just dug around to avoid bothering anyone at first.
Anyway, I went through the new instructions and moved things around a bit. In your instructions you state, "Make sure that there is a "Dist" folder in each of the Chassis (F01/F10/F25) folders etc."
My psdzdata folder (now in it's proper place) has nothing but files with the pattern psdzdata.7z.001 through 030. There are no subdirectories in C:\E-SysData\psdzdata.
I'm also not sure where the cafd* files should be. I guess they should be copied to C:\E-SysData\CAF?
Joe Morris
2013 X3 28i (prem, tech, cold1&2, conv, hud)
