Old 11-30-2012, 04:36 PM
skwidrific skwidrific is offline
Mein Auto: 323i, Ducati M1100
Originally Posted by DPP528 View Post
Here's how I see it;
$796.00 Oil Filter Housing gasket (Oil is leaking onto the block)
$4-500 is about right for that, it's involved and must be done
$610.00 Front Rotors and pads (I already knew that was going to be the case)
ask whoever else you go to for OEM parts, ~2 hours labor, should amount to about $400
$323.00 Rear Tires are at minimum spec (Had an idea that was the case)
You should be able to get decent tires at a tire retailer for about $130 each mounted and balanced
$180.00 Alignment (Had an idea that was the case)
Alignments are worth about $75 tops
$190.00 Rear Diff service (That was a little surprise)
To change the oil in the rear diff? it's $20 worth of diff oil and 30 minutes labor, tops. the diff in my car takes like 1.1 quarts
$165.00 Power Steering Fluid exchange (That was a little surprise)
that's outrageous
$165.00 Coolant Fluid exchange (This one is totally unnecessary as I replaced my radiator earlier this year)
I agree
$430.00 Fuel Filter replacement (This was a little surprise)
$40 for the filter (the good one) and an hour's labor is quite generous
$2,859.00
Total expense should be about $1,1-1,200 at a fairly pricey/reputable indy shop, which is worth it, but $2900 isn't
Best of luck
Thanks for the input. It looks like you and I are on about the same page... I'm looking to get everything on that list done PLUS changing the trans fluid and filter and a VANOS rebuild for less than $1,200. I priced out 4 new tires and alignment for $505... I figure if I'm getting 4 new tires for roughly what they quoted me for 2, then I'm doing pretty well...
