Bimmerfest - BMW Forums - View Single Post - Tire wear at 23k miles
Old 11-30-2012, 07:03 PM
ard ard is offline
Resident Curmudgeon
Originally Posted by kanar200 View Post
Is the toe 0.01-0.03 the only value I should asked them to set? Is it still in the BMW spec? If not, can they refuse to set it?
kanar
The BMW spec (by memory) is 0.00 to 0.08 each side. So asking for 0.02 on each IS still IN spec. But dealerships can be lazy, if they toss it on the rack and the numbers are 'green' (ie in the spec) they USUALLY will not change them. Just have them write your wishes IN THE REPAIR ORDER. Just make it clear you have specific needs in advance and they should accomodate,
On the other numbers, they should just be in spec. I like Camber in the middle of the range AND even from side to side.
GL
A
