Thread: 2003 ZHP Camber
Old 12-02-2012, 07:29 AM
QAfred QAfred is offline
Mein Auto: 323i, 330ci, R1200C
Originally Posted by Dathaeus View Post
Thanks guys! Makes me feel a lot better.. will have to take it to my lifetime free alignment at Firestone since I just got new tires but nice to know.
Should I actually take the #'s above and take it to them? I wouldnt be surprised if they were not familiar with a ZHP's specs. I hope they dont do a bad job but I have been going to them for like the last 10 years. They always give me a computer report when I ask for it etc... (P.S. I have 17" BBS, not sure if that matters)
BMW tech told me as long as you stick with stock set-up you will not have excess tire wear. He claimed the issue is; that most shops do not ballast the car, and therefore you cannot get an accurate toe adjustment. He said he has noticed that camber was not impacted as much as toe was once the car had the prescribed ballast installed and stated without the ballast toe will be out, especially in the rear, and abnormal tire wear will result.
The Hunter alignment machine automatically brings up the spec on all cars and it too states to load the E-46's with ballast. Firestone tech told me they won't buy it for him so when asked by the machine if ballast is installed he pushes the yes button and drives on...hence the error in toe and camber- since BMW says you are tricking yourself/the machine if you think you are going to get a good alignment without ballast.
