Thread: coding HUD
Old 12-02-2012, 03:24 PM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
You should be able to enable the M elements in your HUD, there's only one HuD hardware & it is coded according to the car it is fitted to. Similarly the MDrive menu can be enabled in any iDrive system but it doesn't do anything, you can select P400, P500, P500 Sport but it does nothing. I think the HUD functions do work though.
As for Sport mode on by default, I don't think this is possible. You might be able to make up a circuit that provides a momentary pulse of positive (or negative, would have to check that) power supply to the back of the Sport switch at start up. There is no code to do it anyway
Legal Disclaimer remove
Module: CAPPL/MASK
Parameter: LEGAL_DISCL
Change required: aktiv -> nicht_aktiv
Seat Belt chime remove
Module: ABG & SGM (2 modules for total disable, just disable ABG if you want it to bong just twice)
Parameter:
SBR_BEIFAHRER_ACSM (Driver)
SBR_FAHRER_ACSM (Passenger)
Change required:
Video in Motion
Module: CAPPL
Parameter: VIDEO_DENY_C0B
Change required: deny_slow_key -> deny_never
There's tonnes of changes on top of this that can also be done like adding a digital speedo
