Old 12-02-2012, 06:30 PM
MikeyBabii MikeyBabii is offline
Car Crazy
Mein Auto: 92 BMW 525i
Originally Posted by robertobaggio20 View Post
So are you saying that you did not have coolant and smoke from your tailpipe with the old pump, but you have that with the new one? Did you check just before you changed it out ?
In any case, water pump failure is not supposed to lead to problems like this. Do the compression test. Ignore the vcg for now. Post your results here and we'll take it from there. I might have a good solution for you as well.
I had a little bit of smoke with no smell of coolant with the old pump. With the new pump it is a lot of smoke and strong smell of coolant now... I'm guessing because the impeller is actually working now that more coolant is flowing. I'm sure it's one of the gaskets I just don't know which one.
