Bimmerfest - BMW Forums - View Single Post - ABS and traction lights on on E 39 540i
Old 12-03-2012, 02:13 AM
OGIEVA EMOKPAE OGIEVA EMOKPAE is offline
Send a message via MSN to OGIEVA EMOKPAE
Mein Auto: 5401 E 39no
I had driven the car for at least 6 months after i repaired the sensor cable, and everything worked perfectly. The first sight of the problem was on my way from the Alignment Bay. We confirmed the faulty sensor visually by a physical examination. Changed it (although with a wrong unit as I later found out ) the brakes work fine once i disconnect the speed sensor, and the same occurs when i disconnect the ABS module. My mechanic at the time did not use any error reset tool, but I have a Wednesday appointment to check the fault and possibly reset this ...I hope this helps
