Old 12-03-2012, 12:01 PM
legend700's Avatar
legend700 legend700 is offline
Mein Auto: 2008 535i
As to item 13. of the above write-up, I would like to point out that the bleed process is different in the Bentley's manual for the N54 turbo engine. It is an automatic sequence initiated after selecting the lowest fan speed and heat set to max. and holding the accelarator down for about 10 seconds with ignition on. The automatic process runs exactly 12 minutes and shuts off by itself. Also coolant reservoir cap needs to be closed.
Attached PDF lists details.
2008 535i Monaco Blue
PP, SP, SAT w/paddles, AS, CA, L7,
NAV, PDC, Heated F Seats, SIRIUS,
iPod+Aux, Bamboo Anthracite Wood Trim,
Gray Dakota Leather
