So cleaned up the connections and unplugged the computers. Reconnected them and let the car idle. Took it for a drive and there was an improvement. The first shift is perfect. The second and third still Rev a bit. Instead of reving 500 to 1000 it only does about 200 to 500 on hard acceleration and on normal driving shifts fine. So that process helped quite a bit. I'm tempted to put a bottle of lucus into to see if that helps that last bit. Or would something else be better than that?
