Coding Error
My car just recently had a software update at the dealership for a cold start issue, however it reset all of the coding I'd previously done back to the factory settings. Now when I try making changes in CAFD in the FRM module for example, as well as other modules that I've coded before, I get the following error message when I select "Read coding Data":
Transaktions-Report: Aktion: Codierdaten lesen
FRM [72] [C807783]
readCPS o.k.
cafd_0000012f-012_003_011 Fehler:
File for "cafd_0000012f-012_003_011" not found! [C012]
I tried making a change to the CAS module, which I've never made any coding changes & did not get an error message. I was able to code in the module.
Anyone else encountered this problem?
