12-03-2012, 07:25 PM
Mein Auto: bmw
Originally Posted by brewder
I have the Xenon's... headlight shake is NOT normal. I don't care what the SA tells you. I had mine repaired using SIB 63 10 07. Now mine are ROCK SOLID like the Xenons in my Audi are and my halogens in my Suburban!
Keep in mind there are variations of this SIB based on the model of your car....
Headlight Vibrates when Vehicle is in Motion
MODEL
E92, E93 (3 Series)
Vehicles produced from May 31, 2005 to February 11, 2007
SITUATION
The headlight shakes or vibrates when the vehicle is in motion.
CAUSE
The front-end carrier arm of the headlight is very sensitive to vibration.
CORRECTION
Do not replace any parts. Perform the following procedure to both headlights.
Check all connections that are used to secure the headlight. If screws are missing or not sufficiently secured, then they must be replaced or tightened to correct BMW specifications.
If the headlight still vibrates:
2. Secure the headlight arm with additional screws P/N 63 12 8 372 243 (1).
3. Install an additional headlight arm support (1) to both headlights, P/N 51 64 7 019 777 (Left) and P/N 51 64 7 019 778 (Right).
4. Remove the front bumper cover per repair instructions RA 51 11 156.
5. Remove the left and right brake air ducts.
6. Remove the round-head Torx bolt (1) to install the additional headlight arm support.
7. Install the additional headlight arm support (1). Make sure that the support surface of the headlight arm support (1) engages onto the headlight carrier (2).
8. Secure the other end of the headlight arm support (1) with a new self-locking M6 X18 round-head Torx bolt (2) P/N 07 14 6 978 618.
9. Reinstall the left and right brake air ducts.
10. Reinstall the front bumper cover per repair instructions RA 51 11 156.
PARTS INFORMATION
Part Number
Description
Quantity
51 64 7 019 777
Headlight Arm Support (Left)
1
51 64 7 019 778
Headlight Arm Support (Right)
1
63 12 8 372 243
Additional Screw
4
07 14 6 978 618
M6X18 round–head Torx Bolt
2
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
63 12 02 37 00
Labor Operation:
63 99 000
Work time for installing the 4 screws in step #2.
Labor Allowance:
3 FRUs
Labor Operation:
63 99 000
Work time for installing the 4 screws in step #2 and
both headlight arm supports.
Labor Allowance:
15 FRUs
Wen I look up the part number on getbmwparts.com, it says that the brackets are for a 2011 328i. Will it still work?
http://www.trademotion.com/parts/ind...&siteid=214672
