Thread
Clever way to check for vacuum leaks?
12-04-2012, 10:21 AM
bluebee
View My Garage
Originally Posted by
1972ford
any thoughts about how else to pinpoint a possible leak?.
I've tried the brake cleaner - but - for a pinhole leak, intermittent leak, or for buried leaks (such as the lower CCV vent hose), it just didn't work for me.
- Does the order of the misfire OBDII DTCs diagnostic trouble codes actually matter (
1
What worked for me to find the cause of my plethora of non-specific lean-misfire codes was a $30 smoke test!
- How to make your own smoke machine (
1
The result was this underside leak, which the brake cleaner didn't get to:
And, this huge leak, which also the brake cleaner (and presumably propane) can't get to:
Moral of the story:
Based on my one experience tracking down lean misfire codes, I recommend a smoke test or simply replacing all the hoses.
- How to diagnose a BMW M54 engine misfire (
1
) & a cold-engine intermittent misfire (
1
Note:
Your mission
should you decide to accept it
, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also:
E39 Bestlinks
How to easily find what you need, in seconds!
10:23 AM
bluebee
View Public Profile
Find all threads started by bluebee
Find all posts by bluebee
View My Garage
Add bluebee to Your Ignore List
