Old 12-04-2012, 12:45 PM
-=Hot|Ice=-'s Avatar
-=Hot|Ice=- -=Hot|Ice=- is offline
Re-Badged
Mein Auto: 2013 BMW M3
1.)Auto Start Stop only works in certain conditions. If the temp is below 37 degrees, it won't turn the car off. If the engine hasn't warmed up, it won't turn the car off, if the cabin temperature isn't at what it's set at, it won't turn the car off, so a lot of things come into play when it comes to start stop and when it works.
2.) Someone with an M-Sport F30 chime in
3.) When you pull into your driveway, push the park button on top the gear lever once. Open your door and shut it. Lock the door and the Radio will turn off. BMW's keep the car powered for up to 8 minutes.(used to be 20 on older model cars) You can listen to the radio in that time frame before the car automatically shuts the power off to save battery.
4.) You can stream your Android based phone through bluetooth as well. It's not exclusive to the iPhone. As long as your phone supports A2DP, then you should be able to hear music play through the cars speakers.
Originally Posted by CaptainAudio
In the words of one of Bimmerfest's greatest minds:"Been there, done that"
Originally Posted by boltjaM3s View Post
Half the fun of succeeding in life is fighting the fight and making it.
