Old 12-04-2012, 04:38 PM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
Originally Posted by petriej View Post
Once the car is running, all electrical power is effectively delivered by the alternator. Your symptoms are a tell tale sign the alternator is going bad, not the battery going bad.
+1. I would have the alternator checked. You could do it if you have a multimeter as well. If you connect the leads to the ground (Car frame) and to the +Pos terminal before starting the car, you should be reading battery volatge of 12V DC. Then start the car and you should see the voltage go up to approximately 14V DC. this should remain a constant value. If the volatge is irratic, then the alternator regulator might be bad. (I'm going by memory here so bare with me )
2008 650 Convertible- 6 Speed manual- Sport package- HUD- Lane Departure- Comfort Access- Merino Leather- HD Radio- SAT
