Bimmerfest - BMW Forums - View Single Post - 2004 X3 3.0 Radiator Fluid & Transmission Leak Questions [Update]
Old 12-05-2012, 12:33 PM
awdrev awdrev is offline
Mein Auto: 2004 BMW X3 3.0 Auto Tran
Originally Posted by x3brian View Post
I was meaning that BMW changed the recommended service interval in the glove box maintenance guide from lifetime to every 100k miles in 2007. The ironic part is its the same fluid. Things that make you go hmmm.
They also did the same thing with spark plugs between 2009 and 2010 (same part number though). The service interval went from 100k miles to 60k.
For transfer case go get the BMW fluid and do ASAP! It easy to do just remember to get two new copper washers.
I was under the impression that the washers were fine to be re-used... as long as the dealer has them, I would not mind getting them though.
