Bimmerfest - BMW Forums - View Single Post - 2004 X3 3.0 Radiator Fluid & Transmission Leak Questions [Update]
Old 12-06-2012, 03:16 PM
x3brian x3brian is offline
Mein Auto: X3
Good work! You should be good on the fluid in the xfer case. If it was slightly dripping out or if you could feel it it at the top you are fine.
Glad to know about that support! Taking it down crossed my mind once too. I ended up using a box wrench to remove the fill plug.
Haha about the coolant. Same darned thing happened to me. I filled the coolant with the bleeder open and then stupid me used to domestics turned the car on to fill it up more with expansion cap open. I was given a pretty waterfall of blue coolant every where. Lesson learned...that's what the bleeder is for.
