Old 12-07-2012, 09:59 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Correct. Continuity means zero resistance. 0 ohms. It's really two switches in one housing. It tells the ECU it's either a closed throttle with one switch, or a wide open throttle with the other. In between (throttle part-way open) it should have infinite resistance between the center contact and either of the outside ones. When the throttle is closed, the idle side turns on the idle control valve (through the ECU). If the TPS is bad or adjusted incorrectly, the ICV can't regulate the idle.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
