Bimmerfest - BMW Forums - View Single Post - Crank fan delete
Old 12-07-2012, 11:00 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Originally Posted by Kdoherty View Post
Also to the OP (that's you JDMdudewhatever) the clutch fan weighs so little that you will get NO extra power by removing it. The electronic fan is meant to supplement the belt driven one, and not perform the whole duty. Our engines are very susceptible to overheating, and once you do you'll either wreck the head which is bookoo dollars or you'll blow the head gasket which is nearly as expensive to repair if you can't do it yourself. So to save yourself money in the long run, not to mention the brand new radiator you're probably planning to install, replace the damn fan and fan clutch
i searched it for you and took LESS than 5 minutes
http://www.pelicanparts.com/cgi-bin/...ch%20%20%20%20
^fan clutch
^fan
EDIT: You'll also need a new waterpump if there's a ball bearing missing. http://www.pelicanparts.com/cgi-bin/...0Each%20%20%20
This.
In shorter words, dont remove it, replace the broken stuff.
Have piece of mind
Sent from my SPH-D710 using Bimmer App
-Dino
