Bimmerfest - BMW Forums - View Single Post - Crank fan delete
Old 12-07-2012, 06:25 PM
JDMwizkid JDMwizkid is offline
Mein Auto: 1993 bmw 325i
Originally Posted by southpark11235 View Post
By "stage 3 cooling refresh kit" do you mean this one. if so the Stewart pump should last for ever. Are you sure it is failing? Also did you change the fan clutch and blade when you refreshed the cooling system. If so and the wobble started right after you refreshed it then maybe you installed something wrong.
i have not installed the refresh kit yet.. its on its way.. and i dont know that it is failing but i know that the vibration cannot be doin any good at all for it
this is why im hot
