Thread: Transmission
Old 12-08-2012, 07:48 AM
Scarmukha Scarmukha is offline
Mein Auto: 540i
Hi I have 97 540i with an Auto Tranny... Am having the same problem as well. Been getting TRANS FAILED message quite often and this puts the car to 5th gear running only(don't know if that sounds right).. Been able to cancel this and back to normal by re-starting the car.... am confused on the solution to this problem.... I have a Range Rover L322 with the same engine and Tranny... had the same problem but Land rover was able repair by changing the Gear Selector Switch... I wonder .. would anyone know if that would be the same solution....It's a expensive part to replace. Thanks
