Old 12-09-2012, 08:00 AM
Leekay07 Leekay07 is offline
Mein Auto: X5 35D, Former X1 and 335
My extra tire warranty states on RFT they replace the tire for any kind of puncture.
Run flat tyre repair
Run flat tyres are built with reinforced inner walls, and are designed to continue running, even after a puncture. Run flat tyres have traditionally been impossible to repair, leaving customers with an expensive repair bill, as new tyres can cost as much as 200.
Those customers looking for a run flat tyre repair have been told in the past that it isn't possible, as it was too difficult for tyre fitters to tell if the side tyre wall had been damaged. With standard tyres, a tyre fitter was able to spot the damage in the side walls through creases which showed up. With the reinforced run flat tyres this become more difficult, and traditionally the advice was to completely replace the tyre.
Sidewall damage caused by driving a tyre for more than 50 miles, or over the recommended speed with a puncture is difficult to spot, but drivers who have developed s low puncture and have not driven the car with a puncture would argue that they should have their tyres repaired as there is no way there could be any side wall damage.
For their own safety, tyre fitters could not take their word for it, from fear that they may be dealing with someone looking to save money by not having to buy a new tyre.
In the last year both Michelin and Bridgestone have announced that it is possible to carry out a run flat tyre repair, assuming the tyre is no damaged.
The tyres will be checked for heat build up caused by driving a run flat punctured tyre for more than 100 miles, or over 50mph. BMW also claim that a tyre which has been run too long with a puncture will start to show a build up of balls of rubber inside
If you like customer service. Don't look beyond a BMW.
