12-10-2012, 03:38 PM
Test... 1, 2 ,3
Mein Auto: 2012 M3 - 2010 CC
Originally Posted by wassy
Ok then. I guess I'm stuck with what I have. Although other systems do sound a little better on Sirius and in shocked there is that much difference. That's what DIRAC should be for. To up convert to a higher bit rate if possible.
Some Sirius channels have higher bit rates than others but fundamentally the improvement is not something to be proud of. The best reported resolution has been 60kps (music), and as low as 15kps (traffic)
DIRAC is to make you feel as close as possible to a soundstage and not to upconvert the source. But overall it is not that good in a car environment, IMO -I used to have that OEM system in my old M3 and I coded it out. Logic7, Euphony and even Dolby ProLogic II are better in a car environment -again, IMO.
You will be complaining about some other sound issue the same with it, for sure.
