Bimmerfest - BMW Forums - View Single Post - Mechatronic sleeve issue - transfer case clearance
Old 12-11-2012, 07:53 AM
pcy pcy is offline
Cheap Infrared thermometer (around $20) can read trans fluid temp without having to connect to fancy BMW diagnostic equipment.
As OP said, pretty soon, BMW will require all passengers to be registered/programmed to the car so that the car can calibrate itself. During the registration process, electronic chip will be embedded in to all registered occupants' **** :-)
