Old 12-12-2012, 09:04 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
Originally Posted by kharripe View Post
Just got the whole cleansweep setup and I have know idea how to install it, I know the wires connect to the speakers but where would it go through the l7 or what? Please help
In all honesty, return it.
The Cleansweep is barely 4 channel audio with FL, FR, RL & RR signals. There is no dedicated subwoofer channels, tweeter channels, etc. You are going to need external crossovers to split up the signal and get the sound right. Adding more insult to injury, the factory system has WAY to many inputs for the cleansweep to accept! To fix this you need to spend more money on a JL summer (http://www.jlaudio.ca/cl-ssi-car-aud...egration-98112) to add up the signals.
IMO, do it the right way and get an Rocksford Fosgate 3.Sixty.3. It has 8 channel inputs so you can do the FL Tweeter and Mid, FR Tweeter and Mid, the subs and then the RL & RR mids. Then you go through PROPER tuning software with a mic and other stuff and tune it to YOUR LIKING.
OR you can get the JBL MS-8 which you hook up the same way as the 3.sixty.3 and setup a mic and set it to auto config. The HILARIOUS part is that it uses Logic 7 processing
