Old 12-14-2012, 09:52 PM
kanar200's Avatar
kanar200 kanar200 is offline
Mein Auto: was 530d, is X5d 2011
why 0.05? you wrote (from memory) that the BMW spec is 0.00 and I should demand toe between 0.01 to 0.03 (i.e. something around 0.02 above the minimum spec). They told me the BMW spec is 0.03-0.13. therefore I thought that 0.05 would be OK since it is 0.02 above the minimum
This is not BMW computer - should I be worried whether the spec are wrong? I think they are using hunter alignment system, if it means anything
is setting alignment out of spec (to minimize the wear) something common?
unfortunately I do not follow the rest about rear toe spec, cross toe, etc.
Ultimate Towing Machine - towing Jayco 28DSBH (2017)
