transmission leaking
I have a 1989 735il, I recently replaced oil pump seal on tranny and put a speedi sleeve on snout of torque converter and when i fire it up it leaks a steady stream out and after some time it slows down to a drip. Just wondering if anyone has ever had this problem or would know what to do to fix it. Also i posted before about the tranny not shifting outta first, I have plenty of fluid in tranny now but seems only time it will shift through gears is if i hit the switch to manual. Im not familiar with the bmws so i trying to learn and get any help possible.
Thanks,
feit87
