Bimmerfest - BMW Forums - View Single Post - need advise, 2008 X5 trany problem
Old 12-17-2012, 08:17 PM
Brando7 Brando7 is offline
Mein Auto: 2000 328ci
Originally Posted by ard View Post
I am basing that on my meager knowledge of BMWs. The car should not go into failsafe mode for 'no reason'...there will be a fault code.
Dollars to donuts he will reset it and give it back to you. Try and get you to keep it until the dealer can blow you off. Dealer is paying this guy, right? Probably the shop that does all the work for the used car lot?
I'd bring it to a BMW dealer, spend the $$$ and get a real diagnosis: if the BMW dealer says "car is fine, we cant explain it", then you are as good as you can get. But if the BMW dealer sees issues, NOW is the time to press your case.
Penny wise, pound foolish?
GL
Good point. also if cpu is reset will that clear all fault codes?
thanks for you input
