Old 12-18-2012, 02:15 PM
ChuckE89's Avatar
ChuckE89 ChuckE89 is offline
Mein Auto: E81, E89
the pump for the windshield is the one on the rear, towards the firewall. push it towards the rear of the car a bit [like 1/2"] and then pull up and wiggle, and by wiggle, I mean you will dwarf your efforts to get away with forgetting your anniversary, it should move pretty much straight up, and hopefully the strainer will come with it. If you are replacing the pump, then best to replace he strainer also. If the strainer does not come out with the pump, then you will need to grab it with some needle-nose pliers. and get it out, as the strainer usually clogs pretty easy and you may find the pump is good, but the strainer is not.
2007 120d Limited Sport Ed
2009 sDrive30
